Chalk Outline
Just won a
sketch1 said:What stereo are you upgrading from?
Chalk Outline said:Just won a
teotwaki said:I've been watching EBay and the prices are all over the map. The cheapest was $17 plus $12 shipping. The owrst was the newest 2006 model with 3 knobs, IPOD and color change that was a Buy-It-Now for $285
Chalk Outline said:$285 must have been for the 6 disk changer. I paid $86 + $15 shipping. That seemed about right. Another '06 went a day later for $80 + $15 shipping.
To be honest, I am having 2nd thoughts about putting this in. I may stay w/the stock unit and add an external amp instead. I'm looking at replacing the stock speakers with Focals and they may want a bit more power than the Scion Hu has.
The one for $285 was not a 6-disc unit. It was the absolute latest model but only one disc
microjoe said:The only problem I have is that there is a high pitch whine when using the XM so I had to stop using the PIE unit and go back to the FM transmitter. I found information online that suggests grounding one of the RCA shields will eliminate the noise but I have not had a chance to pull the HU out again to test it out.
pipspeak said:Hey Microjoe... have you had a chance to ground it yet? If so, where would one ground it to? I haven't taken apart my dash yet but will eventually be installing the same setup as you (Scion 06 plus PIE adapter).
Anyone else experienced the PIE whine?
Mountaineer said:I switched out my input cable (mini plug to RCA's) from my XM Roady2 to my PIE with a longer cable and started getting the engine whine. When I had a shorter cable there was no whine. When I installed it, I bunched up the new cable with a zip tie in the center console under the trim. I took it back apart and untied the cable and stretched it out so that it did wrap around or touch itself anymore. No more engine whine. I don't know if will work for anybody else, but it worked for me.
