Pink Milkshake - a success story.
Patrick4R
I just wanted to submit an update for anyone who has had the dreaded mixing of fluids from a bad radiator. My 96 SR5 (142K) 4x4's fluids got to know each other early in January and after reading several posts here...I was nervous it was a death sentence. I was able to get it home and about 1 week later I was able to get it into my garage. I replaced the radiator, thermostat, transmission filter/fluid, and flushed the block with several gallons of hot water. I also flushed the heater core as best I could. After the initial fill up, I drove it for about a day and decided that I would drain and fill the transmission pan again. It shifted better each time I drained/filled. I had no major indicators of damage in the original transmission filter. I drove it to work for about 4 week (13 miles each way) just to be sure I wouldn't end up stranded due to delayed transmission failure. My success story ends with a 700 mile trip to Cincinnati this week with not even a hic-up. In fact, I drove about 110 miles in 4WD until the road disappeared under Monday's snow storm. These things are phenomonal in the snow! I plan on one more drain fill for the transmission after the weather thaws here in Pittsburgh. Anyone else had good luck like this?
Patrick
When I bought my Runner in July it was shifting very rough. After a little investigation, I realized that the radiator had been replaced for this same reason. Las fall, I drained and refilled the transmission three times (shifting getting better each time) with a planned fourth change when the weather changes here. So far, so good.
Good to hear that your truck survived the strawberry milkshake! But yeah, hope everything keeps going smooth with your transmission.
How did you know that the radiator was replaced? Is there an OEM sticker on the original one?
Mine had a sticker on the radiator cap that mentioned something about the warranty of the radiator being void if the system wasn't flushed.
