My Koyo just showed up today. Ever since I had my TB, Water Pump and T-stat replaced my truck seems to be running hotter and hotter. This is likely a result of idiot mechanic not using Toyota Red coolant and mixing with Green. They are not compatible and will crytalize blocking the radiator eventually. So now I am doing Radiator, T-stat and hoses. I might do the Fan clutch just to be safe. BTW I have 217k on original.
Auto shop recommending sticking with my original unless I was having a problem.
They used green coolant since that was what was in there already. I'm guessing it's ok to go with the green so long as you are not mixing the two?
