I have recently purchased the Pioneer AVIC-D3 Nav unit, Bluetooth hardware, XM receiver and back-up camera - I started the install on Sunday but quickly put the dash back together when I realized I had more questions than answers. I need help...lots of help....
1) Wiring Harness - The harness on my OEM radio (2006 base SR5 Radio - no JBL) has three connectors going into the back of it. The harness for the new radio appears that it will only use two of the OEM connectors. Is the third connector (with the narrow pin terminals) used?
2) Antenna Leads - The OEM radio has two antenna wires - one larger in diameter and one smaller. The Pioneer radio only has one connection for the antenna. Is it necessary to use both of these antenna leads and/or is there an adapter that allows me to use both in the new radio?
3) Interior Trim Removal - I would like to install the MIC for my Bluetooth unit next to my sunroof switch. To do so I need to route the MIC wire behind the A-pillar trim piece and under the head liner. Is it difficult to remove the A-Pillar trim piece?
4) Exterior Trim Removal - I would like to remove and notch the chrome trim piece above my rear license plate to accommodate the B/U camera - similar to the OEM installation. Is this piece difficult to remove? How does it come off?
5) XM/Navigation Antenna Locations - Has anyone come up with a creative location for their Nav or XM antennas? My best guess at this point is to install the antennas in the center of the dash (close to the windshield) and route the wires through the defrost vent. Any other suggestions?
Any advice would be greatly appreciated!
