Planning to lift, what else should I change?
zoombyu86
I'm planning on lifting my 2000 T4R. It has about 142k on it. The tie rods will need to be replaced for sure since they're frozen together on one side. Should I just change anything else while I'm down there even if all looks well given my mileage?
I read something once about using Tacoma parts. Is it cheaper or just "stronger"?
tacoma parts aren't necessarily stronger but meant to carry a little more weight if any. You have a northern 16 year old truck then I would do some maintenance as well(diff seals/diff flush, check all lines/hoses, check for rust where upon lifting or modding could cause damage, check oil pan and trans/trans. filter, brakes and all that jazz). Then do the lift and definitely do bushing especially sway bar.
OTREs and LBJs are a good choice when lifting.
You might as well plan on replacing the CVs (or at least rebooting the originals) when lifting; those suckers will probably be slinging grease everywhere before too long.
AndiGarage
