Please critique my maintenance strategy
retiring2texas
I am not a mechanic. I don't have the time, tools or know-how (yet...) to do what needs to be done. They got me by the short hairs I guess. My brother took the shop classes, I was the college prep dude taking calculus...
90 4runner, M/T, 3.0L V6.
Bought it new in 90. My Dad owned it 95-07.
Everything stock.
137000 miles.
Back-ground info:
I just drove successfully from Florida. 900 miles at 57 mph, 26-29 mpg. Not a problem, Starts fine. Runs fine.
Sags in the rear like an overage stripper.
Brake fluid looks darker than one of those Bavarian beers.
Rusty brake fittings where the A/C condensate dripped on it.
One blown CV boot. Others look ready to go.
Everything coated with grime and cob-webs.
It has been sitting undriven but covered since at least may 06.
Well, just minor start-ups and a bit of movement every few weeks by the neighbor watching the truck.
My Dad was ill health and finally passed away in July 07.
I am registering it to Texas so it goes through the state inspection. It seems lame. General safety items only.
Here is what I plan to have done.
Oil and filter.
Lube the chassis. (eventually I get my own grease gun & DIY)
Inspect M/T, differential & transfer fluids.
Flush coolant sustem. It looks kinda brown...
Flush brake fluid.
Replace the rusted brake fittings.
Rotate and balance tires. Tires relatively new (125k, 8/04).
Replace CV boots and ball-joint dust covers.
Repack front wheel bearings.
Replace timing belt and water pump.
Adjust valves, set timing & idle.
Replace spark plugs.
Replace original rear shocks and maybe coil springs.
Check drive belts, replace as needed. 2 done at 129600, 5/05.
I went through all my dad's maintenance records.
It was a bit sad to always see his distinctive scrawl...
Fuel filter done at 130505, 8/05. So, it is OK, right?
New battery at 124116, 7/04, so it seems fine.
New clutch slave and master cylinders at 119349, 1/04.
Pulled 4 wheels, check brakes, scuff up drums with grinder, test drive sat at 125022, 9/04.
Replaced front brake rotors and pads, cleaned and adjusted rear brakes, repack and replace front wheel bearings, replaced r/s cv boots. 99602, 5/01.
New muffler, tailpipe and hangers. 78000, 1/98.
(Exhaust system looks really rusty. State insp. checks for leaks.
I might have to do this now, but definitely will roll it in soon)
Replaced distributor cap, rotor, wires, starter contacts at 94943, 12/00.
QUESTIONS: Well, you guys that do your own work are probably cringing now but I don't have a choice really. I need this vehicle for a few more years so I gotta pump in some dough.
Should I do the front shocks while I am at it?
Original shocks with 137000 miles I guess.
No noticeable problem but when the truck is this disassembled is it cheaper to have them replaced?
Should I replace the original oxygen sensor?
I will replace the air filter myself!:D
And maybe even the fuel tank cap gasket if someone walks me through it. Slowly please. :D
All my dreams of a suped up 4WD with big tires, a lift kit, other new add-ons and seat covers and a CD player will have to wait.....
I will let you know what they say they will charge me.
I call at 2PM today to get the estimate and authorize them to press on or not....
Also, I will tell them to keep all the old parts so I can see the condition and at least know they actually did something, right?
Or is there a trick around that to screw the consumer?
I think that's a longest post I ever seen. I'd say: yes replace all shocks and O2 sensors.
what a great thing to see the oldies comming back to life!
yeah man it really looks good!
well after reading the whole thing im impressed! i would prob let you work on my truck!
good work and keep it up!
she's back from the shop
Well, I had to rob a few liquor stores but I paid the bill.
The truck seems great. I made them show me the old parts and did test drive it before paying and did look it over for about half-an-hour. I caught a few things, minor coolant leak, one zerk not lubed. So I talked them into a 10% discount.
Looking back now I never should have had them to do so much.
hindsight is 20/20. Next time I will just take it for a few items so they focus.
A couple things they didn't charge me for because they didn't think it was needed.
Who was moaning about my long posts? No one is forcing you to read it... Just kiddin', Hey, I'm here alone, nothing else to do. my wife and boys arrive from Italy this weekend. So, I'm shining and cleaning the truck.
Thanks and good luck.
It sounds like you got it all worked out. I'm sure it'll run great. I love those 90's 4Runners. If you got any pics post it.
