Please help, engine replacement isnt fun
ejohnson84
So does anyone know if a 4runner body with fit onto a extra cab long box pickup frame?? i know the pickup has a longer wheel base but i can make the body longer if i need to, I mean im a auto body tech not a mechanic, and i just cant do this engine swap. Please help if anyone knows if this will work.
the 4runner is a 1990 and truck is a 92 so they are the same model year, same engine as far as i can tell from the front doors forward is the same.
I am almost positive that the 4Runner uses the same frame as the pickup.
Mike
Not sure if 2nd gen Runners are the same, but 1st gen Runners used the same frame as the std cab/short bed truck, and are totally swappable.
well i just did some measurements between body mounts and it looks like it might be possible, the front 2 are the same, the 3rd mount is 5 inches farther back, and the back three are too tall, so i just need to do some cutting and welding to get it all to line up properly.
tobasko556
