Here's what I have (working on it for a friend in need):
1998 Toyota 4Runner, 3.4L V6, Automatic, 2wd, 186,000 miles
It was pretty much pouring oil off the back of the motor when she brought it to me. I checked up high first, but nothing serious around the valve cover gaskets or back of camshafts. Pulled the dust cover on the bottom of the bellhousing, where a lot of oil had even been trapped, and it appeared to be coming out of the back of the oil pan. Pulled the oil pan, someone had recently tried to fix the leak with silicone on the pan, no gasket though! It was obviously leaking in a couple of spots near the back of it, so cleaned it all up, new gasket, installed the oil pan, and washed off all the old oil. Seemed to be fine at first, but after driving about 10 minutes began to smell oil burning, so stopped and looked and it's back to pouring out again right at the back of the motor!
My questions:
What are the most likely culprits? (Even if it's something I've checked, going to double check)
And she didn't change her oil regularly (going even a year or more and SEVERAL thousand miles between changes) so could that have caused a major failure of the rear main seal? (I've just never seen one leak this badly) Or possibly something else related to that...?
Thanks guys, this one really has me stumped and it just seems like it should be so obvious!
My questions:
