Please Help Tail Gate 2nd gen
Pavel
Hi everybody,
I introduce myself, my name is Pavel, I am Belgian and I live in Australia.
I recently get a 4Runner SR5 V6 1992.
I bought it really cheap (1500AUS) at a guy who used to work in the desert.
Lot of sand and dust, runs on 5 cylinder, A/C , taillights and Tailgate down.
I quickly solved the engine problem (a broken ignition Lead), repaired lights and aircon with two fuses.
Remains the Tailgate ...
I don't own the trunk key, the guy who sold it to me told me that he never had but the switch worked "a week ago ."
I checked all the fuses, played around with the wipers, but no reaction.
The window is in closed position, and no noise or reaction when I press the switches on the center console.
Have you any idea about this issue
before I start disassemble everything?
thank you
Cheers
Hi everybody,
thank you
Cheers
https://www.dropbox.com/s/6azfu48z5jgl0wr/backdoor.pdf
^ Here's a link/downloadable pdf file for the whole rear gate diagram. Back window failure is a common occurrence, i used this to help fix mine. It was as simple as just replacing the motor/relay though. If you need more help, just ask! If I can't help, someone will be able to!
ps- The window lock button on the drive console will lock the rear window switch, just like it does the regular window buttons. So, just double check that too. Also, I have heard if the back wiper is screwed in too tight, it can actually keep the window from going down.. so, check that too and get back to me.
Good Luck,
-TJ
AndiGarage
