Pop noise in driveline after lift
mx381
Hello ... Installed a Rough Country 3-2 inch lift on my 2017 4runner. Since then it seems I’m getting a pop in the driveline at slow speeds when taking off and applying brakes at slow speeds. I don’t feel it only hear it. And I may be crazy but it seems it gets worse when it’s cold and wet and happens much less with dry conditions.
Has anyone experienced this after a lift or have an idea what it might be ?
Thanks guys for any input you may have.
Marc
First off, to bring up an old standard on the Forum (which seems to have been lost recently). Put your exact setup in your sig. This way people can answer your questions without guessing what you have. It's right their in their face on every post.
Put things like year, model, suspension (KDSS or not). Lift shocks... It' just helps people understand the context of the question/comment.
But If I had to guess your issue without more info I would say one of two common problems.
1- Sway bar is contacting radiator support brackets.
2. LCA bolts are not torqued to spec...
I would also suggest to grease the driveshaft slip yokes. It may take 10-15 pumps of the grease gun to make a difference initially, then after that it's just a pump or two every oil change.
Ok thank you will do after this post but in the mean time.
2017 4 runner sr5 no kdss 3-2 Rough county block lift with new rear shocks installed. Nitto Ridge grapplers 275/65/18
Jhunt
