Popping applying brakes
4Real
I just started noticing a popping noise that seems to be in the rear when applying brakes at low speeds intermittently. Not hearing when up to highway speeds but only at low speeds In parking lots or driveway. Any ideas?
Could be sticky shoes...
Did you unbolt your panhard bar during your rear lift? If so, Id go and lube it up with some chassis grease and torque down the bolt. Mine tends to pop.
Nope, didn't unbolt panhard. The pop occurs immediately when pressing the brake before vehicle really begins to slowly. Would this occur with sticky brake shoes? Not seeing any axle grease on inside of tires. Although I did spray paint some of the undercarriage a little today.
