Porting heads and different cams on a 3.0L ?
Subyswamper
How well do the 3.0L heads respond to a mild p&p job? I haven't seen the heads off of my '92 runner yet but I was wondering who had experience porting them with good results? I am familiar with porting done on subaru's so a set of yota heads shouldn't be too much different. Also I had considered sending the cams to delta camshaft to get a torque or mid range cam grind done on them. Any experience with either would be great before I tear into it.
Also what head gaskets are best for getting the best seal and life out of them when I go to put it back together?
Well I figured a few things out and I am going to start digging away at a yota I spotted in the junkyard. Also I am toying with the idea of fabbing in a supercharger.
Porting
I just did an extensive port job on both of the heads on my son's engine.
I bought him his 4runner in march with a knocking engine, it's a 91 that is in mint condition.
Anyway, I purchased another engine that was rebuilt and yanked the heads and ported the intake and exhaust ports to the size of the gasket openings.
The only thing that I was not able to do was a comparison as the runner was bought with a knocking motor and I was unable to drive it.
Anyways, today was the first time I drove it after I got it running two days ago. What I have noticed is that the engine does not have a massive amount of passing power on the hwy, I tried to merge onto the interstate this evening and there was a semi coming in the lane I was heading into, I punched it and the engine was a dog.
Well, one thing I have not done yet is check the timing, I know, I know, your supposed to, when I started it the other day from the first crank it fired right up and purred like a kitten.
I'll play with the timing more and post the results later. Hopefully it's off and an adjustment will solve the dog issues.
Bryan
I can understand if you want to do something different. But you are polishing a ****.
Swap in the 3.4. Want more power? Supercharge it.
