Possible IAC valve problem...need help.
SE1904
So pretty much, I have somewhat of a rough idle and when I shift gears my RPMs bounce from high to low or low to high. I am thinking it may possibly just be an IAC problem...the problem is...I am having a hard time locating it under the hood. Any help is welcome. Thank you.
I have a 1995 Toyota 4Runner SR5 V6 3.0L 3VZE engine.
I'm not sure on the 3VZE but typically the IACV can be found on or near the bottom of the throttle body there will be 2 small coolant lines running to it so should be a dead give away. A sure fire way to diagnose a IACV problem is to tape off the little hole in the TB just in front of the butterfly, if the problem goes away once taped you have a IACV problem which can usually be fixed with some compressed air.
Its built into the throttle body heres mine with the little cover plate removed.
Picture007.jpg~original
