Post level kit issue
Jmcbride15
So I just installed a 1” level spacer up front. after installing and putting stuff back together, turn truck on and abs light, traction control light are on. And the 4wd light is blinking non stop. Install I thought went smooth lol, what got messed up that would cause these 3 dash lights to come on?
You broke at least one of the ABC sensor wires. If you're good with wiring you may be able to fix it otherwise you'll need a new one.
the post above this one is the most likely cause, losing the wheel speed signal messes with the 4wd as well due to crawl control / a-trac
Front sensor wires are very fragile. I see these posts all the time after guys install lifts. Don't feel bad, you're not the first and won't be the last.
Yep front driver abs wire broke, Toyota dealership wanted $140 to plug in a new wire, not including the $70 for a new wire, so I just ordered it to do myself.
seltzernator
