i am lifted in the front with OME coils and tokico shocks tire size is 255/85/16 i rub a bit on hard turns as the wheels are 0 offset410toy said:just looking, what size tires are those on your green 1999? I have a 2000 with the same fender flares. did you have to trim anything? do you have a lift? oh and it looks bad ass!
How are you going to do that? Just screw on a solid antenna and remove the fuse for the motor?SIKHILUXSURF said:im gonna convert mine over to the manual antenna for the 4runner. lest parts to break.
JeremyH said:How are you going to do that? Just screw on a solid antenna and remove the fuse for the motor?
I am guessing the attachment from the motor to the antenna is broken on mine...I can hear the motor running, but the antenna stays down. It doesnt really bother me, but sometimes passengers ask about it.....which is kind of fun, because I usually respond with something like "That's the ejection seat calibrating itself..."![]()
Haha....I wasnt planning on using the antenna much. I dont really like terrestrial radio. Heck, I even thought about just putting in a CB antenna where the current antenna sits.maurzada said:I've been told by many that to get to the antenna motor is not for the faint of heart and difficult to get at.
Does anyone have an experience in replacing theirs?
410toy said:hello all, I have a 2000 4runner with a power antenna; the antenna is broke in the up position and I want to replace it with something better any ideas? If so can you post pic and part numbers. thanks again![]()
trd_4runnin said:You guys should look into the taco whip style antenna. I don't have part numbers handy but you should be able to find it by searching Taco Whip antenna mod on here or yotatech.com.
Basically you purchase a non motorized antenna assembly from a base model 4runner and then purchase a whip antenna from the Tacoma. Installing the antenna assembly can be done by pulling out the fender liner. It's not incredibly easy but not difficult either. The trickiest part is running the new antenna wire, but you could always cut and splice if thats the only problem you have. The Tacoma antenna screws right into the antenna assembly and is super durable.
edit: Here are the part #s
Parts
Antenna Assembly: 86300-35090 (list price $36.94)
Tacoma Whip antenna: 86309-AA040 ($27.38 at my dealership)
JC_ez said:I installed the taco whip antenna and am very happy with it! Like stated, the hardest part was putting in the new antenna wire. I scraped my hands a bit on some sharp metal pieces behind the glove box area. I do not recommend cutting and splicing antenna wire since the impedance of the antenna wire is tuned. Cutting and splicing the wire will yield poor reception in most cases.
