wife's 01 had the antenna cable break, so I got on ebay and ordered a $20 replacement. Followed the directions here and pulled the motor out, got the old cable bits out, put motor back in, fed new antenna into motor, everything works fine. That was in Feb.
About a week ago the antenna started making a very brief grinding noise when it fully extended, still goes down fine. Today it went all the way up, then started making a grinding noise and continued to do so until the motor run-time ended. Still goes down fine, and goes up fine, but it's like the motor isn't stopping when the mast reaches full height. I held my hand over the tip of the mast and stopped it just a little lower than full extention, and it stopped fine, but if I allow it to fully extend, the teeth start jumping.
I pulled the mast, and while the teeth aren't particularly deep, no part of the cable appears any more worn than the rest. I pulled the motor and the cog wheel in the motor looks fine.
Are ya'll using OEM Toyota masts or what? Did I just get a bad one? Anyone point to a specific place to buy one that they've had success with?
