bosmob New member Apr 5, 2011 #1 Where are you supposed to put the silicone lube? Plastic teeth or metal mast?
S sirunner New member Apr 5, 2011 #3 bosmob said: Where are you supposed to put the silicone lube? Plastic teeth or metal mast? Click to expand... how much did your power antenna cost? Mine is broken too and I've been pulling it up and down manually for over a year now.
bosmob New member Apr 5, 2011 #4 sirunner said: how much did your power antenna cost? Mine is broken too and I've been pulling it up and down manually for over a year now. Click to expand... $26 total, shipped to my door
bosmob New member Apr 5, 2011 #5 packers15 said: Plastic teeth. Click to expand... Really? I was reading the side of the can of silicone lube I bought and it said in bold: DO NOT USE ON PLASTIC There was already some yellow stuff in the motor when I pulled it apart though. Is that enough?
packers15 New member Apr 6, 2011 #6 When I installed mine I didn't add any, I thought there was plenty in the motor also when I took it apart. It's been working fine for 2 months now.
bosmob New member Apr 7, 2011 #8 zombie said: Where did you order it from for that price? Click to expand... 4 Runner Antenna Mast 1990-1995
