power antenna replacement?
All you have to do is take out the antenna mast socket (the chrome thing that goes around the mast's base)... use some needlenose pliers and just turn it.
Take out a few clips that hold the inner fender on, you can reach in and get a white bag. Inside is the antenna and yeah. Take it apart and it's pretty obvious.
I replaced mine when I bought my 4Runner cuz it was bent. I saw the Taco Whip mod but I hate antennae that show, I like it retracted since I never use the radio.
Thread revival..
Does anyone know how you remove the fender liner? I'm trying to remove the plugs that the flares bolt into that also seem to double as holding the liner in but I feel like I'm going to break the plugs.
Yep, sounds about right. I broke a few but no biggie. You can go about the top ones through the engine compartment.
All the plugs I needed to remove were accessible from behind. Just squeeze the back of the plug and push it through. No plugs were harmed in this process :)
