NIK0
I would appreciate if someone could offer a solution. I would rather fix this myself and save getting ripped off by the dealer.
When I purchased my 98 4R about a month ago, the seller mentioned that for some reason the alarm when activated, does not trigger my power locks to lock. You have to manually hit the door lock switch then close the door and hit the alarm. Just to add, when I deactivate my alarm the locks unlock just fine!
Conclusion: my power locks do work as I can lock/unlock my doors with the door switch. This must mean my alarm system is faulty somewhere.
the purpose of this thread is to solve a problem related to the power locks but I thought I would add the info above as it may be important.
The problem is with the drivers side key lock. When you insert the key and turn to lock position, the doors should all lock! Not the case for me. When I turn the key to unlock, they all unlock!! Trying the same thing on passenger door, both lock and unlock work perfectly fine.
So question in this thread has finally arrived.....does anybody know how to fix the key lock problem on the drivers side? Or is this somehow related to my alarm problem too???
