sweetscience
Has anyone had any trouble with their power seats moving forward and backward? 2001 limited.
Recline works fine and the motor sounds strong but is binded when trying to go forward or back.. I took the seat out and found no obstructions. Plugged it back in and tilted the seat back to see if the gears are turning, which they are not. I can turn the gears manually with a socket but the motor will not turn the gears. They twitch a bit but don't turn. The long screw that runs from one gear to the other, turns when you use the motor but it's not turning the gears.
Any ideas are appreciated..... thanks
