Power Steering Pump HELP!!!
kpnavarro
The woodruff key cracked when i pulled off the pulley, were the hell do i get a new one? The new pump doesnt have one, you are suppose to reuse the old one
You could try to weld the broken one together or make a new one. The Dealer may have one, but you probably have to special order it.
Yeah it looks like it will be a fun time with a file, thanks for your guys quick response, this forum has saved my butt a few times
Try a hardware store, or just use the half you've got. They've got all kinds of automotive stuff at Ace hardware. Find a close fit and make it work. Good luck.
the new pump should have came with a new key.
all that i have changed, have had a key.
try a different pump, maybe it fell out/was stolen, or they forgot to put it in the box.
I replaced my PS pump a few years back. Let me check if I still have the old part sitting around. If I do find it, it's yours for postage.
I guess ill go back to see if they forgot to put it in. Is it ok to drive it with it completely installed but not habe rhe pulley hooked up?
I just realized i f....ed up i just got the dam woodruff key but just put power steering fluid into the pump and realized it says dextron ATF fluid on the cap, do i have to drain it and put ATF fluid in it?
p/s fluid
Do you self a favor and use, or flush it with Mobil 1 synthetic ATF. Standard p/s fluid is garbage.
regards
