Main issue: Driver's window stuck in open
All windows were up when I pressed the unlock button on the key fob. That immediately sent the driver's window coming down (never happened before).
That, to me, seems like a short was triggered.
No action from the driver's window, even after toggling the window lock switch, holding the control in up or down for several seconds, restarting and trying again, slamming door shut with 'window up' held, or any other reset ideas I could come up with.
Recent history: Rear passenger window stopped coming down from main driver's controls. Previously, it was stuck closed ONLY from rear passenger control. Now fully inoperable.
No motor sounds when holding the switch in up or down mode.
Still need to check the fuses.
Had the door trim off about 1 month ago to remove the interior handle for painting. Maybe the first time that trim was removed??
Maybe the individual switches are going bad one by one??
Any thoughts while I continue to explore would be appreciated!
