Premium side mirrors work on non-Premium?
DeepSea
Anyone know if the wiring is compatible on the powered Premium side mirrors to work on non-Premium? I ask because I want the option of their built-in blinkers when navigating through traffic.
Unfortunately No, they are not plug and play. Different connectors, different door harness, and the dash harness wires to the Turn signal ECU are not there. Sorry to be a buzzkill.
All good and thanks for the info. Keeps me from a giant headache of figuring it out the hard way. :cheers:
I've installed a newer Gen2 Tacoma OEM side mirrors with blinkers on to an older 2006 model with out any problems. They used the same connector to control the mirror, but have missing pins for the turn signal. Had to manually find the wires for the blinker on each mirror and connect them to the turn signal wires in the car. Very doable, not impossible. I'm sure anyone with automotive 12volt experience could do it without a problem
if traffic doesn't care about your other blinkers they won't care about blinkers on your mirrors
Y’all should be happy he wants to use his blinkers. So many people don’t use em at all.
I see you’re in Hawaii, Hope you’re doing well.
Jhunt
