What turbo are you using? Where are you sourcing the intake and exhaust manifolds? And are you gonna FMIC or gonna use the hood scoop and put a Top Mount InterCooler? I'm just curious, I like turbos, I have no knowledge of turbo'd runners...
This is a no brainer.
Oil supply - Install a T fitting between the oil pressure sender and the block.
Oil return - Braze a 3/8" or 1/2" fitting right onto the oil pan.
what are you using to control fuel/ignition? piggyback system? or are you spending alot on a full custom ems? also are you going to be switching to a map sensor? or staying with toyota gay maf sensor?
I got the automatic so I am stuck with the stock ECU. So ignition is going to stay the same but the fuel is going to have some upgrades. Larger injectors, better fuel pump and URD 7th injector kit so the engine wont go thirsty. Because I am sticking with the stock ECU im sticking with the MAF.
With the MAF setup I was thinking, being a forced induction setup wouldn't it do best with the MAF as close as possible to the throttlebody. Regardless of how close the MAF is to the throttlebody it will have to be after the blow off valve. If it was in front of it or still right after the filter it would be getting flow past it with the blow off valve being open and the throttle closed.
I'm going to say neither of you is very familiar with turbo systems.
"The turbo timer would work best being a electronic and have the capability of building boost sooner and let off boost at a cruising speed. With a manual turbo timer there are two types. Both work generally the same but the down side is they let air out all the time or almost all the time. With that the turbo takes a little longer to get to full boost and less low end power. With that being said if the engine is getting boost at a cruising RPM it can be a bit touchy and a little harder to control."
Turbo Timer? What you are referring to is a boost controller, turbo timer is very different.
"The MAF as to mounted between the air filter and the turbo."
Why? people use a blow through set up all the time ... in fact some of the Subaru's that use the exact same MAF sensor switch from a draw through to a blow through system.
The other thing i will say is that using only a fuel controller on an engine designed for NA will be nothing but trouble. Not only will the stock ignition curve most likely be too aggressive for any real amount of boost, but depending on your fuel control and the method it uses it can actually advance the timing map even farther.
My new to me turbo. Holset hx35w from a dodge ram cummings diesel. The compressor wheel is broken but those are cheep. I was came across clownmeat's 4runner and decided to get working on mine. I guess im not all talk like some say...
So where to tap for oil. Pressurized for going to the turbo and a good spot to return into the engine on the 5VZ-FE soon to be T.
Any suggestions?
There is a 3/8 npt plug right next to the pressure sending unit you can use as well but it's before the oil filter if that doesn't bother you.
I did the drain back in the cap because I did a rear mount turbo and it can be handy if your scavenge pump gets crap stuck in it you can just pull the cap and visualy see if/how much oil is coming back, and it was easier than pulling the pan. If your turbo is underhood then gravity drain it to the pan.
I have a slight idea where that is at.
Im not to worried about getting a clog or something in the pump. I keep a eye on my oil and make sure its clean, but you never know shi$ happens. The only thing that I wonder about with the oil cap settup. How do you twist it on and off wouldn't the return line bind?
