Pro Comp 7189 Wheels
sporty87
Thinking about Pro Comp 7189 Cast Black wheels 17 x 8" for my 10 Magnetic Grey SR5. I would like to put on 275/70/17 tires and would like to know if these would be a good fit not to get any rubbing with the Pro Comp wheel specs. being 0 Offset and 4.5 backspacing. I am not sure if they are Hub centic. I have Bilsteins in the front set at 1.75" and 1" lift being installed in the rear.
Also does anyone know if the Pro Comp 7189 Cast Black Wheels are flat black, or satin because I can't find a good explination of this.
What are the offset and backspacing on the OEM SR5 rims?
If I don't get these wheels what specs of offset and backspacing should I be looking for keeping in mind I will only be moving up to a 8" rim and a 275/70/17 tire and just looking for a more wider beefier look over stock?
You should be good with the offset (spacers not needed). This is a little over 32" and will (most likely) require some trimming to prevent rubbing. These are not hub-centric (but almost all after market wheels are lug centric). The trimming & "centric" are not a big deal and should not stop you from purchasing what you want.
