well i decided to go with the trekmaster shocks. here is what my current setup is and want to make sure i get correct shocks. i have a 97 v6 2wd 4runner. part #'s for the rear of 2wd or 4wd use the same trekmaster shock. but up front the shock are different for 2wd or 4wd. im going with 99 coils in the rear and up front i will have existing coil with the daystar 1.5" top mounted lift spacer. im assumming i need to order order shocks for a 2wd right? rear shocks are same so that doesn't matter. i know it sounds dumb but just want to be sure since this is 1st time doing this. thanks
