speedracer33
My new '03 4Runner needed brake pads, so since I'm going to use it to tow I upgraded to more aggressive pads. Not like race pads, but ones that are good to 1000F (Axxis Ultimates). A couple of days have gone by, and this morning when I started it the ABS and VSC lights came on. They stayed on after I restarted it, so I took it to the dealer, and they said it was throwing three codes: yaw rate sensor, L4 Postition Switch, and low master cylinder pressure.
Is it possible that the harder brake pads are throwing off the sensors because the caliper can't press them into the rotors as hard, and as a result these errors are coming up? I also switched to ATE Super Blue fluid, but I can't imagine that having an effect. Has anybody else had this kind of problem before? Can the OEM Toyota pads handle the kind of heat that towing about 4000lbs (with trailer brakes on both axles) puts into them?
