Problems with master cylinder?
pirho451
The right rear caliper went out on me last week and apparently blew a seal along with it, causing a major leak. As I was driving home, the Brake and ABS lights came on, along with a loud continuous beep. I finally had time to get everything apart yesterday and replaced the caliper, both rotors (originals, too thin to turn again), and pads. Got everything back together and went to bleed the system, but the lights and beeping continue. What's my next step here? The shop manual seems to point to the master cylinder power supply system but I have no idea how to check that.
Nevermind, it finally fixed itself. Had to let it sit with the engine off and the key in the on position for about 15 minutes, with the ABS pump cycling on and off, but it's fine now!
