alexplantman
Hello all... I am having trouble programming a key fob I purchased on Ebay for my 02 4Runner.
After reading the link below from the archives... I tried it 3-4 times and couldn't make it work
.. I just bought a new battery for the key fob, just in case the used one I bought has a dead battery... I haven't installed it yet..
The key fob I bought has some #'s on a sticky in the back, but the steps below didn't mention I needed them.. what gives?
Can someone lmk if the instructions below are valid for an '02 ?
Thanks alot..
Key Fob archive thread
Thanks alot..
1. unlock all of the doors in the car, open the driver's side door, and make sure the key is not in the ignition
2. put the key into the ignition and then pull it out without turning it or anything
3. within 40 seconds, lock and then unlock the doors five times using the power lock button on the driver's side door.
4. close the door and then open it again
5. within 40 seconds lock and then unlock the doors five times again using the power lock button.
6. Put the key into the ignition and turn it to the on position (not acc and not far enough to actually start the engine) and then back to the off position, then back to on and back to off.
7. Pull the key out of the ignition
8. If you are successful, after about 5 seconds, the doors should power lock and then unlock on their own. If that doesn't happen then try again from step 1.
9. within 40 seconds, hold down the lock and unlock button simultaneously on the remote for a second. Then release and hold down the unlock button for 3 seconds. The power locks should cycle again once on their own. If they don't cycle exactly once, repeat this step from the beginning with the remote again.
10. Repeat step 9 for every remote you want to program. You have to do this with any remotes that were previously programmed because this process essentially resets what remotes the car will respond to.
11. Close the driver's side door to signify that you are done programming the remotes
