Proper 134a Charge amount?
jasonran
Hey guys, anyone know the proper low side pressure for the A/C system? What charge level indicates a "full" charge?
Thanks! How does that convert with the typical pressure meter that measures whole numbers-? For example, with the system on high, my measurement shows 32 (lbs?). Is that the right pressure?
The low pressure side translates into 22 - 36 psi.
The high pressure side should be 199 - 227 psi.
The test conditions should at 86 - 95
