Proper jack points for garage jack?
ciaz
The manual has them laid out quite clearly, however when I get down under the car I can't really see what they are referring to.
Where is the best place to jack up the car with a garage jack? Where do you put jack stands?
A nice photo how-to would be great!
:rtfm:
Since the 5th's frame is based on the 4th's. The front, jack under cross member between the front wheels and jack stands on the frame rails where it flattens out. The rear, jack under the diff pumpkin and jack stands under the axle as far out and as close to the rear wheels as possible (near the trailing arm mounts).
Can you point those out on an illustration?
