Proper psi on geolanders
Justin.Geer81
Junior Member
The beasts look amazing! But the damn things will hold 80 psi! Have them at about 35 right now ... just wondering if I should be running them higher?
I’ve always run the sidewalk psi ... but 80 just seems so damn high
Thoughts?
285/75/17 size on a 4runner obviously ...
Thoughts?
80PSI is the max. No need to go to 80psi...Check the manufacturer's load inflation tables to see if 35psi is good for the amount of weight you're carrying (I have a feeling 35 should be fine).
Toyo's article on determining PSI: https://www.toyotires.com/media/2125/application_of_load_inflation_tables_20170203.pdf
Thread with some discussion of it: Load Inflation Tables and Correct PSI
