PSA: Please use the search function
You can use the "Search T4R.ORG" search box (above in the header) as well. It works really well and is really fast.
one of my favorite PSA videos on posting
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/B9q2jNjOPdk?fs=1&hl=en_US&color1=0x006699&color2=0x54abd6"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/B9q2jNjOPdk?fs=1&hl=en_US&color1=0x006699&color2=0x54abd6" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
The lack of searching before posting isn't as annoying as some of the posts themselves.
People can't take the time to put together a coherent sentence.
Run-on sentences like this
hey no input have you stupmped well here is some more went back to it agian the owner stopped last night and we bled brakes the old way pumping up oh buy the way i found a leak above the shock bracket filled with dirt fluid finally seeped so i could find it by accident replaced lines from mid section to hose and both cyls any way bled system no pedal brake light came on why no prop valve this morning went out had one quarter pedal no brake light on the dash had this happen before air began gravity bleeding no air now no pedal again used one man bleeder on system nothing at all went over all connections tight tried bleeding the abs nothing seems to make a differance nobody here has any input? is there a site on here that will take you to toyota tech assistance? im pullin what ive got left of my hair none of this makes any sense im begining to think its in the abs because of the fluid loss in the system been there done that before but this takes the case of beer!
**vehicle was brouht to me with no brake fluid in master cyl looked over no leaks but found calipers froze hoses cracked rear shoes not making contact no leaks replaced calipers hoses and master cyl no leaks at master also pedal stiff then fades to the floor pressure bled gravity bled no brakes went to dealer not any help cant find any load sensing valve brakes adjusted no weak wheel cyls bled good clean fluid booster dry where did fluid go and whats up with no pedal any body out there got an idea
are jibberish. If you can't take the time to create a decent readable post, don't expecct much of a response.
I've run a vBulletin forum myself and the fault really is on the poor search function. I'm about as familiar as one can be with the software and still have trouble finding stuff too. There are some search mods/add-ons that can help over on vB.org but it really comes down to tolerating the re-posts.
I agree that using Google will yield better results than the native search function though. Be cool with it, don't bust anyone's chops and if you're familiar with the content gently refer someone to the thread by posting the link.
Just my 2 cents. ;):
Yeah, I'm a newb here myself...
People can't take the time to put together a coherent sentence...... are jibberish. If you can't take the time to create a decent readable post, don't expecct much of a response.
I couldn't agree more. Sadly however, these posts are not a matter ot time.
All the time in the world won't cure writing like this - a HS education maybe, but not time.
