PSA: Your Amazon Hi-beam LED headlights are garbage.
Hammeredsole
I posted this in another forum, and I figured I would share it here. I realize that I'm not the most subtle person, but I feel that this issue needs to be discussed. On an almost daily basis I am blinded at night by someone who "upgraded" their headlights in their car. This was a well recognized issue with HID's, causing them to fall out of favor. Lately, however, LED retro-fit manufacturers have taken the torch of creating bulbs that claim "Proper Placement". This is true, only to the extent that the center of the LED emitter matches the placement of the center of the incandescent coil. Marketing material completely disregards the void where no emitters are present on roughly 90º of bulb circumference, nor do they discuss that the emitter profile is physically larger than the incandescent coil itself.
I posted this is response to a bunch of folks fluffing up the Xenon Depot 9005 retrofits, that they were raving about working with their DRL. If you don't feel like reading the whole thing, I will sum it up. Retrofitting LED 9005 bulbs is NOT an upgrade. You are paying for the color alone, and actually losing lighting performance. If you're okay with that, cool, but don't think your getting anything useful out of the equation.
_________________________________________________________________
The geometric reflector of the hi-beams is tuned for a very small incandescent filament that emits all of its light in a 360 degree pattern from a very small surface area emitter. An LED, on the other hand, emits all of its light from 2 panels that emit at only about 270 degrees from a relative surface area that is about 2-3x larger than the filament of an equivalent incandescent bulb.
So, from emitter placement alone, we have an LED that is engaging entirely different parts of the reflector design, putting light where it doesn't belong. Additionally, entire portions of the reflector aren't being engaged at all, due to the 2 sided design of LED bulbs. So, the net effect is an apparent increase in brightness because suddenly there is LIGHT EVERYWHERE! Wow, these things are bright, and that must be better, right?
The 9011 is roughly a 2,350 lumen bulb, and I'll (arbitrarily) give an optimistic Chinese LED headlight 3,350 lumens to give it a clear 1,000 lumen advantage. The long lasting OEM 9005 are roughly 1,550 lumens for reference.
We have the 9011 that will engage the reflector at exactly the right angles, putting exactly the right light pattern for Hi-beams onto the road; a narrow focused cone of light. All of the 2,350 lumens are projected to precisely where they need to be.
We have the LED with 3,350 lumens, engaging the reflector at the wrong angles, scattering the light over entirely new areas of the road. It appears bright, because there is more light. But much of the light isn't where it's supposed to be. In effect, the reflector is scavenging less light from the designed emitter geometry. If you trimmed the LED emitter size to be the same as the incandescent coil, lumens would be far less than the extremely condensed 9011 incan coil area. They are getting more lumens by making a larger surface.
Next would be CRI, or color rendering index. Which is an easy Wikipedia read, but in summary: the cool white LED is actually worse for depth perception and detail recognition than a good old incandescent. In fact, LED manufacturers make great strides to get LED color closer to incandescent. Color temperature and CRI often follow each other, but are not the same. A warm LED with the same 2700k color temp as incandescent will still never be 100 CRI. It is very expensive to build a high CRI LED, and also decreases the efficacy of the LED output at a given amperage in comparison to a "cool" white. In practice, high CRI (incan) also causes markedly less glare and eye strain than low CRI LED's (cool whites). A good way to think of this is this: 1 single high CRI (100) lumen is 100% effective to the human eye, while a low CRI (65) lumen is only 65% effective to the human eye. It's not quite that simple, but it's an easy way to understand. The 9011 bulb is 100 CRI (although lacking in the blue spectrum... blue is not desirable in night time driving anyways), while the LED in question is absolutely no higher than 80 (even if it was a high end warm Nichia bulb, which its not), it's more likely in the mid 60's.
Sure, LED headlight's lumen output is higher when it is measured at the emitter. However, I would wager that the candela measured at a distance of 100m from an LED (when installed in an incandescent reflector housing) is drastically lower than a good incandescent bulb in the same housing.
People are literally paying for less real world performance and reliability. To top it off, they are now blinding other drivers when they're driving around in their car with super cool LED headlights.
A cool way to understand how the reflectors are working is to grab a low powered flashlight, go out to your car, and really try to find the incandescent coil reflection in the reflector housing bands. You will see that it is almost like looking at the coil with a magnifying glass. Try the same with an LED, and you will see that you can see large areas of the reflector are engaging circuit board material, and entirely new areas of the reflector are engaging LED emitter from entirely inappropriate angles.
Marketing will have you think the LED emitters "are in proper placement"... sure they are, enough to sell a bunch of product. A final kick in the balls is that the Xenon Depot 9005 are merely rated to 1,750 lumens, meaning they have a very marginal increase over OEM 1,550 incandescent bulbs, with all of the draw backs of improper emitter placement and lower CRI, but they also have a MASSIVE 600 lumen deficit to the homely 9011 (at approximately 400% the cost of a pair of 9011).
Agree 100%. . I drive ~140K ml a year sick and tired of those aftermarket (upgrades)
Amen
Seriously, the OP is right!
Let’s make it clear, a lot of light is surely safer BUT only when it end up in the right spots - in case it doesn’t you’ll get the opposite effect. Maybe the blinded oncoming traffic “decided” to turn than ugly blinding light off and dumb there vehicles directly into yours - it could be pretty awful.
but, depending on speed, it doesn’t hurt for long.
So don’t buy sh.., do it right or don’t do it at all
Gotta agree, you would be better off replacing your incandescents more often (and so much cheaper) than retrofit LEDs. If you really want LEDs you should buy a whole new housing that was built for it.
I agree with the OP. On a two lane narrow state highway it gets dangerous specially when there is no shoulder and the oncoming traffic blinding you driving in the front range through the mountain roads.
good leds in the high beams are so vastly superior to incandescent bulbs its clear to me that the posters that say otherwise have never been the behind the drivers seat of a car equipped with them. i do, however, admit that they are blinding as DRL and should not be used as such. but as a high beam, the throw is so so much further
Proper HID's in a vehicle that comes with them from the factory have always been my favorite. They throw light very far. I always figured they were better than LED's, but maybe I am wrong. HID's do suck in the rain though lol.
That's all well and good, but when Toyota decided to mount LED fogs at 4500-5000K paired with incandescent low and high beams at 2700K, it looks like ass.
Bring me the 5K incandesents and I'm on board.
Note: This is mostly tongue in cheek. Mostly. It does look like ass. :lmao:
good LEDs are not sold on amazon at all. PERIOD.
good led's come from OEM lighting ONLY. PERIOD. no ifs or buts!
thank frigging god my cars now have auto dimming rear views.. never thought i would ever care for this feature
Is there so much fog around Vegas all the time?
Fog lights as the name maybe reveal are for foggy weather, the lower attachment purposes to shine below the fog. The headlights should be off in that case since they would only bright up the fog...
Sure, I seen fog lights misuse before, especially teens use them to show receptiveness or something like that but I think you’re one of those!?
Here's the thing, they're useful in dust too ;) but Toyota in their infinite wisdom defaults to requiring the headlights to be on in order for the fogs to be on as well.
My bad, I did not except that kind of stupidity from a manufacturer.
Fact is that the fogs definitely give better light in conditions like fog, heavy dust or even heavy rain but not when combined with headlights.
But I can imagine that’s a easy fix!
Anyway, the thing is that a lot of this “bright up your stock headlight”-kits are unsafe since they blind almost everyone else and that can’t be the solution!
I mean back in the days a h4 In a ordinary reflector housing was the common headlight, hard to imagine but a lot of people, me included, survived the lack of illumination.
My biggest complaint about the factory headlights is that they are too high, even if you make them brighter they are still too high.
I plan on fitting driving lights in the factory fog light location it just hasn't made it to the top of my priority list yet
Like the Joke, wasn’t a attractive execution but the idea behind wasn’t that bad!
Good information, OP! Thanks for sharing.
I, for one, can’t stand most of the “blue” headlights I see because they’re mostly too bright, poorly aimed, and as you describe, unevenly lit (the word faceted comes to mind). It seems many or most of these folks are happy because their world is all lit up. They don’t seem to consider that the people flashing high-beams at them are doing so for a reason.
Perhaps an even bigger pet peeve is fog lights. Probably 98% of the time I see them, it’s a clear night with no rain, fog, snow, or dust. Perhaps the drivers think it looks cool. The fact is that it’s simply too much oncoming light on a dark road, regardless of how they’re aimed. It’s not cool, it’s idiotic if conditions are clear. They’re called fog lights for a reason.
Unfortunately, there’s no easy way to educate everyone on proper lighting usage. But thanks for contributing good info!
OK this one hit a nerve for me. I realize the title is about high beams, let me take it further.
Guys around here are running ultra bright lights in their fog pockets, light bars on all the time behind their grills, under their chin spoilers, or on their roof racks, searing bright aftermarket LOW beams... it's lame as hell. It's blinding people constantly.
Your low beams should not be searing bright in peoples faces!
Even you guys that think you did it right, aimed it right, bought the right bulbs... 90% of you are still blinding people, it's just that most are too polite to lay the brights on you. I'm not, I'll bright the hell out of you, and in retaliation you'll flip me the bird or turn on your light bar or nail me with your high beams that are searing bright.
None of your junk is DOT legal, but you don't care, it's your safety and driving comfort that matters, and you gotta have that sweet headlight mod the day after you buy your vehicle, and as long as your local grease and go joint doesn't fail your inspection due to your lame aftermarket bulbs then screw everybody else. "I don't give a $#%@ if it's DOT legal it's MY RIG!"
Don't get me started on all the above coupled with the sweet "levelling kits", or heaven forbid the squat reverse rake trucks and suvs.
I group you searing bright not DOT legal light guys in with the squat truck guys. Lame.
Your sweet mods are not so sweet, in fact they can be downright dangerous to other drivers.
Just remember, for every 1 vehicle that flashes you because your lights suck, there are 10+ others that wanted to but didn't. I'll bright you for sure.
Damn, I'm usually 99% nice and pleasant too, this has been bugging me bad though.
Every Jeep owning ******* around here has LED bulbs in big round reflector headlights with no cutoff and they all drive around blinding everyone and thinking they're cool, a lot of those same *******s think that LED light bars are OK for on-road use and insist on blinding everyone just to prove how small their pee pees are
seltzernator
