Ok this is the second thread for the same car from the same guy, cut me some slack, i will slow down on the new posts soon
Ok Vehicle is 1995 4R, green 2WD automatic SR5. It is hit in the back and has cosmetic damage, pics are on the other thread.
Mechanically it looked ok to me, price was very very cheap and i bought it. It has 133000 miles on the motor an carfax shows that the mileage is as stated.
I just put it a new battery, changed the oil and changed the distributor cap and rotor. I have bosch plug wires and some platinum ( original is brass i think) plugs on order from autozone. Radiator fluid is full to the brim and there are so far no visual leaks from anywhere. I also threw in a bottle of chevron injector cleaner to the tank. Don't know if they work or not but whatever.
There is a minor squeking noise from the accesory belt, right at the power steering pump. Visually it looks like there is a very small wobble at the power steering pulley, except that the belts look like they are ok. The timing belt service was done at 64000 miles ( dealer plate on the cover) it has 133 so it may be time for that. Transmission and its mounts seem in good condition. Tranny fluid is clean,red and full, it shifts nicely, with no knocks or jerks, does not hunt gears. It switches from neutral to park to drive to reverse nicely without banging or rocking the car. If i get on the gas pedal it down shifts right away, keeps the rpms nice and high and as soon as I get off the gas it up shifts and lowers the rpms. Cruise control and over drive work fine.
Here are the things that bother me, and i am not mechanically inclined so i need some help here.
Every time I start the car there is lots of water vapor coming off the exhaust. This vapor goes away as the car warms up. During this time, water also drops from the exhaust pipe. I thought it maybe due to condensation inside the cat or something. Does this signal that there is something else wrong with it?
Second is the exhaust smell. It passed smog with flying colors, however the exhaust smell is pretty nauseating. I know even the new car exhaust smell is bad and this car has 130k on it but this feels a little more than the usual. On top of that, when the hood is up and i manually increase the rpm's using the throttle cable, i can see that the motor shudders a little bit on lower rpm's, which goes away as the rpm increase. I can also feel a minor hesitation when accelerating slowly off a red light. I have tested the shudder by removing one of the plug wires and it got worse, so I was suspecting if one of my cylinders is not firing. If it is, is there a better way of testing this?
Last one is, and this maybe connected to the same issue above, when i accelerate I hear this clicking noise coming off the driving column. This noise is hard to describe. I was not sure if it was pinging, so i put in 91 octane gas and tried it out and it is still there. Imagine the click noise of a watch, that repeats itself lets say 2-3 times per second and its click per second increases as the rpm's increase. Is this normal? Is it pinging? Can this be a symptom of a non firing cylinder?
Tnx for reading, its a long post but i wanted to put in all my impressions in one post so you guys can make some recommendations to me.
