Q on 5th gen limited trim diff and transaxle oil change
Cheers!
Member
Hi T4R experts,
Is the differential oil change on a Limited Trim 4Runner the same procedure and spec as the rest of the 4Runner line up?
Same question for for the transaxle.
Thanks in advance!
There is no transaxle on this vehicle. For the 4 wheel drive system there's a transfer case, a front differential, a rear differential, and a transmission.
Right. apologies on the loose terminology being used.
I looked through the factory service manual. It looks like the only difference I could tell is the full time AWD transfer case is that the limited transfer case takes 1.5qts of oil instead of 1.1qts.
The front and rear differential amounts seem to be the same as the other trim levels.
