markeike
I removed my roof racks and rear air deflector to give them a thorough cleaning and/or repainting, and like a bonehead, I neglected to take notice of how the square track nuts go back into the track when I took everything apart.
There are 4 nuts that retain the two raised cross-bars, and 6 nuts that retain the 3 bars that are mounted flat against the roof. The little plastic spring nut carriers for the two types are slightly different, but my best guess is that for both types, the curved surface of the nut should point upward, and the plastic carriers should be on the bottom providing protection for the sharp points and allowing the nuts to slide in the track without digging into the metal.
If I am correct, the result is that the springs for the raised cross members are on the top and force the nut downwards, while the springs for the flat bars are on the bottom and force those nuts upwards.
Anyway, I'd appreciate it if anyone out there could take a look at their roof rack and clue me in on how they should be reinstalled. Please take a look at the photos and see if they look right. In both images, the nut for the raised cross-bars is on the left, and the nut for the flat bars is on the right.
Thanks in advance for your help.
