Question about Fj springs/Bilstein 5100 combo
03v8runner
Hello all, I have an 03 4runner Limited with V8. It has XREAS and RAS.I have decided to get the Bilstein 5100s and pair them with the FJ springs. I was wondering what I should set the front adjustable 5100s to in order to level it out. Thanks in advance for any info.
i would get the adjustables just so you have the option later on to possibly lift/level. That way you only buy it once.
If you aren't getting rear spacers then wanted the factory rake keep them at zero. If you want to level it some them set them to .85"
.85 would give you a level look. Just note that you will be a bit stiffer than stock incase you were expecting the same ride quality.
Ok cool. Thanks a lot. I will set them at .85. Actually the XREAS is pretty worn out and struts squeak like hell every time I drive it so anything will be better. Lol. I would like to raise it more but have rear air suspension so can't really do much with the rear right now.
I can attest to the spring issues in the rear. I have a 1.5" spacer in the rear that measures 23.5" from the center of the center cap to the fender. My front measures 24.5" and I've contacted ToyTech to see about switching springs for the rear. I took out the XREAS system all together and running the Bilstein 5100's on all 4 corners. I got the 3" lift with Light Racing upper control arms to help with the alignment.
Did the FJ springs and bilstein 5100's over a year ago. Have been happy so far. Front set at .85 gives you about the same factory rake as before. The springs do provide about an inch or so lift. Ride is a lil stiffer at times, but it is a truck. You will notice more side-to-side motion without the Xreas. Mild offroading it does great!
What do I need to set fronts to in order to level it?
Does it make a difference on the model when setting the front at .85? I imagine a 4WD v8 would be a lot heavier in the front than a 2WD V6? Reason I ask is I have a 2WD v6 and am getting my swap installed next month. Thanks.
With a V8 I would imagine you will have a very slight rake. Any higher and you'll be reverse. I have the Tacoma coil on mine with a V6 and it's spot on level but I prefer a slight rake being that when the truck is in motion or slight load and you'll end up reverse. And so I have the daystar 1.5 for the rear waiting in the garage.
I just did this swap last month. I used a 1.5 inch Daystar spacer in the rear, new FJ coils, and the front Bilstein 5100s on the first notch up from the bottom (.85?). I tried setting it higher, but the main thing that I noticed was that the downward travel was significantly limited due to my stock upper and lower control arms 'n ball joints. I noticed when I jacked the 4Runner up, with the ride height set higher (second notch up from the bottom (1.75?)), the tires lifted up off the ground rather quickly. With it set just one notch lower, there was significantly more downward travel in the suspension. So, although I actually preferred the way the 4Runner sat with the higher setting, I was really more concerned about the suspension bottoming out when I hit our huge Michigan potholes at highway speeds. In addition, pay attention to the CV axle angle. I don't know how much is too much, but I know when I had a 2.5 inch lift and NOT using a differential drop kit, my CV axles wore out pretty quickly (maybe coincidence).
If I would do this again, I would go with an aftermarket upper control arm that uses a ball joint that allows for more travel in the suspension, THEN put it at the higher setting (1.75).
I measured the slope of my driveway and then the floorboards on the 4Runner and found a 2-degree downward rake in the front...not bad. The ride is firm, but not harsh. If you are raising the center of gravity of the vehicle with a lift, it's a good idea to use the higher spring rate like the FJ coils, as it helps with stability when cornering, and reduces front end dive when braking. The FJ coils are a nice choice for a mildly lifted 4Runner.
Thanks for the info. With my budget and the fact that it's 2WD I'm definitely not looking to get upper control arms or do any major lifting. I also really don't want to cause other costly issues like the CV joints wearing out. Sounds like the .85 setting is my safest bet considering I didn't plan on putting a spacer in the rear either. Main goal is to get rid of XREAS and level it out.
Sounds like a good plan. Without the 1.5" spacer in the rear, you might not even need to put it at the .85 setting. With the V6 engine, you should get about a 1.5" front/0.5" rear lift with the heavier coils. It just depends upon how much settling your old coils had and whether or not the FJ coils are new or used. It may level itself out with the new coils alone.
See how it looks, if you don't like it, then it's about a 20min/side change to the next setting. Once you've done it once, the second time goes much quicker.
