Philbert
HI everyone,
I had a remanned diff installed a year and a half ago. It's now leaking from the seal around the case - not from where the driveshaft enters.
My mechanic said it needs a new seal and would be $400 to replace. I don't have $400.
Is it as simple as (after draining diff oil):
1) Disconnecting the drive shaft from the rear diff
2) removing the bolts around the casing on the diff
3) lifting off the diff case cover from the rest of it
4) replace gasket
5) put together and put new oil in
Or...will the gears and other parts fall out of the casing? If it's not this simple as described above, I would likely have him do it - but I'd rather DIY it. Anyone done this and is it that easy?
4) replace gasket
