Question about spark plugs.
oblivionis
I need to replace the spark plugs on my 2004 T4R V6 with 38300 miles on it. I know some guys put NGK Iridium Laser spark plugs in their 4Runners but that is for the V8 engine. From what I have heard those are not recomended for the V6. So what would be a good spark plug for the V6 engine? I want to put the best I can in there.
I changed my 05 v6 plugs at 30k. Just get what the dealer is selling and that will be good enough. The iridiums are for the v8.
Yes, I can go to the stealer and overpay for some generic spark plugs to be installed but I'd rather spend the money on better plugs and install them myself.
So... the question still stands.
I asked the same question back when I needed to change. There was alot of debate but no real answer of why or why not to use iridium on the V6. I didn't want to risk anything so I picked up the OEM plugs at the stealer. They were reasonable.
Yes, the dealer price is around $2 per plug. Good advice is to use these during your powertrain warranty period.
Changing the plugs is easy on the v-6. There are some good write-ups on this site.
A plug with a precious metal tip might have a longer life but it won't give you anymore power or economy. A plug either fires or not. If it doesn't fire correctly you'll get a MIL lamp (service engine) lit.
Whatever plug you get, you're still suppose to change it out every 30K anyways so might as well just get the OEM NGK or Densos.
I just said to get what the dealer is selling, not have the dealer install them. :twak: Jeeze
I had the same question myself...and decided to do a little experiment.
I looked up the specs on the LFR6AIX-11 plugs from NGK. All of the dimensions are the same (i.e. thread depth, seating distance, gap, etc.) The only other things to be concerned with are current and heat dissipation. Using NGK's charts, the plugs should be the same as the stock plugs. So I wrote to NGK...below is the reply:
"The Iridium IX LFR6AIX-11 should work fine, there is slightly less projection on the IX plug. As for why the truck came with a mix of Denso and NGK plugs, it a pretty good mystery and I wish I knew an answer. Thank you."
K. Zdral
Technical Support Representative
NGK Spark Plugs (U.S.A.), INC.
I have had them now for 10K miles. The results: No noticeable change in gas mileage or power.
I took them out at 15K to inspect them. No signs of abnormal wear or burning.
My main reason for changing them was after reading about te mix of plugs, Denso and NGKs. I was curious and pulled them to see for myself...I thought it was rather odd. I found the Densos to have had significant ceramic burning...at only 5000 miles. Rather then just switch them out with the stock NGKs...I decided to do the experiment.
So far so good. I am not "exactly" sure why they used the standard plugs along with the short service interval. The dealer still uses a 3K mile oil change for the car although even Toyota says 5K. Maybe they just want us to come to them more. All I know is the Iridiums for the V6 work well...and should last longer. I only paid $7.40/ea for them from Sparkplugs.com. If I go double the stock mileage on them...then they have paid for themselves.
They make the iridium plug for the V6 engine also. I plan to do this upgrade when I get to 30k miles. There should not be any difference between using them in the V6 or the V8 especially since the V8 went to the VVT-i (variable valve timing) on the 2005 models.
I'd rather have the iridium plugs than a mixture of this and that.
This is what comes up when searching sparkplugs.com:
Make: TOYOTA
Model: 4RUNNER
Year: 2004
Engine: V6 - 4.0L - FI - 1GRFE
Premium Class
Spark Plugs
Champion Iridium Plug 9202 9202 D.O.H.C. $8.11
Denso Iridium plug 3421 SK20HR11 $11.77
Denso Iridium plug 5344 IKH20 $11.95
Regular Class
Spark Plugs
Denso Traditional spark plug 3381 K20HR-U11 $3.42
NGK V-power spark plug 5788 LFR6C-11 0.044 (Original Equipment Manufacturer, and/or Original Equipment Service Part) $5.08
Make: TOYOTA
Model: 4RUNNER
Year: 2004
Premium Class
Spark Plugs
Regular Class
Spark Plugs
Just bought a set of NGK plugs (LFR6C-11 ) for the V6 from sparkplugs.com. I googled for a coupon code and found one for 10%off. The code is "dodgetalk" if anyone is interested.
Any idea when the coupon expires?
It was posted on the dodgetalk forum back in Feb '06 and still works. The search on google came up with several results, I just kept trying until I found one that still worked.
