cdoyle
Member
Hi,
I've been thinking about doing an LED Retro for the tail lights, and also the bumper lights.
For the tail lights I'm either going to try and mount an already assembled LED tail/brake light module (like those you see on semi's) or construct my own PCB and solder on my own LED's.
My question is, about how to disassemble the tail lights? Does anyone know how these come apart?
I know that some manufactures will glue the lens to the housing, and if you warm them up enough you'll be able to seperate them pretty easily. Others you have to actually cut them open (which I won't even bother with if that's the case)
Has anyone ever removed the lens from the housing on the Runner before?
Same with the bumper lights, but with them I'll most likely build my own PCB since it's an odd shape, and also use superflux LED's
For the tails, this is what I'm sorta thinking about trying to mount in there. Still looking for a better one, but this sorta gets the idea. When they are off, you wouldn't really even see it behind that lens, but when on. You would get that cool LED look you see on the high end cars. I would most likely remove the lens off the module, to let more light out.
