question about TRD 18" BBS rims
V8Limited4wd
I definitely want to upsize to an 18" rim and am very interested in the TRD 18" rims. The question is can i put the stock size 265/60 R18 tires on them? or do i have to put on larger tires because they are 18x9(oem 18" 18x7.5) i wanted to keep the same diameter as stock so the speedo and mileage would be accurate.
I would not do it. I would get wider tires, ie. 275/55's or so. You definitely don't want the tire more narrow than the wheel.
you need to check the mfr specs for approved rim width for that particular tire.. usually it can be obtained at the tire mfr's website
