Question about Valor Chrome exhaust tip.
SR5XM
A while ago I bought a chrome tip, but when I installed it, it sticked out about 2 inches past the bumper (didn't like how it looked).
I cut off some of the pipe, and it was even. One thing is that I had to just drill some screws into the actual pipe (3 of them) to hold it in place, but now the got rusty.
If I put on the Valor exhaust tip with the bolt installation, will there be any problems since the pipe is shorter? Does the valor tip stick out past the bumper?
The Valor will not stick out past the bumper. It will seat all the way to the resonator and C-clamp with one bolt. How much of the original tail pipe did you cut off? You should have no problems since the Valor is pushed all the way as far as it can go before it is clamped down. Just make sure the drain hole is facing down.
SR5XM said:
It was about 2-3 inches I cut off.
Thanks.
You should be fine, plenty of pipe left. Since the Valor is actually secured near the resonator (about an inch away) it should be a secure fit nonetheless.
