Question about XM radio reception.
NAdams65
I installed an aftermarket XM radio in my 2008 T4R recently and now have a question. I ran a line from the XM unit (audio out)
to the AUX jack in the console glove box so I didn't have to use FM modulation. Now anytime I use the XM I get a high-pitched sound that is constant anytime the XM is on. If I go back to the stereo everything sounds normal.
Is this some form of interference or something else? Any ideas on how to get rid of the noise?
Thanks....
Nate
:confused:
Don't suppose the male end of the jack is wet by any chance? I know it's random but that will cause feedback.
Thanks....
Nate
:confused:
Thanks....
Nate
:confused:
Where did you hook the power for the XM? It sounds like you need a power line noise filter.
Re: Re: Question about XM radio reception.
In an attempt to have a cleaner install, I purchased a 12v outlet and spliced it into one of the outlets in the console. Then I mounted (hid) that down inside the console and ran the power cord out the seam where the console meets the dash.....which is where I have the XM mounted.
I guess I could try plugging the power cord into one of the other 12v outlets and see if that makes a difference. Can I purchase the noise filter at Radio Shack?
Thanks for the help....
Nate
