techmen17
So I finally did my own oil change today...I'm at 63k miles so I figure now
is as good a time as any to switch to synthetic.
So the oil change was pretty easy, but I have just a few questions/concerns.
1) After I took out the oil plug I noticed that there wasn't a gasket in place?
The dealership did my last oil change, you think they forgot to put one on?
There is a slight possibility that it fell off into the oil pan, but I checked the pan
after I was done draining it, and saw nothing there.
2) What does the oil plug gasket look like? I put a hard rubber gasket back on..
Was that right, its not a crush washer or anything is it?
3) I let it drain for about an hour, I was doing other things. Reinstalled the plug, put in 5
quarts and checked the level. It looked like it was full already? Actually maybe a little over?
Do you think there could have still been another 1/2 quart or more in the engine?
I'm going to drive it a little, and then recheck.
Thanks, NATE
Thanks, NATE
