Question for Anyone with Andymod 2.0?
redbull9944
I'm contemplating installing the Andymod 2.0 on my '01 SR5.
A problem I keep running into when I'm off roading is the trac/vsc cutting power to my engine even with the Center Diff Lock engaged.
My question is, when the AndyMod function is engaged, and the Trac/VSC is off, does that now mean my 4Runner is limited to an "open diff" front and back?
From what I understand now, the Trac makes it so I have a limited slip diff in the front and back.
I'm worried about off roading with just open diffs, because I know there's not much you can do when you encounter uneven terrain.
Ideally, we need the Trac "limited slip" option working without anything cutting our engine power.
Thanks in advance!
Well the diff lock should still work, because that just makes the power have an even 50-50 split. I just want to know if activating the Andymod will disable my traction control and leave me with open diffs.
Philthyphilthy
