Questions about my newly aquired 4runner
agsingh
i just bought a 2002 4runner SR5 from the US and had it shipped to the carribean island of Turks & caicos. A couple of things i would like to know about it now that i have it:
1. Is it normal for the head lamps to turn on when started and running? if so is there a way to turn it off?
2. It has a few scrathes... nothing major but i like to keep it looking good so i would like to get touch up paint. it is gold ish.... but i would like to find the color code to properly match it. where do i find it?
let me know if you guys can help.
1. Yes it is called DRL or Daytime Running Lights. They can be disabled use the search feature there are a few threads out there.
2. Look on the driver side door jamb, you should see the color code of the vehicle on the white label.
he thanks man! i did do a search and found some topics but nothing on how to disable DRL. can you quote the topic you were referring to?
When on, the transmission lets the engine rev higher before shifting to the next gear when under heavy accelleration or load. Higher revs = more power.
oh ok. How do i know if it is 4wd? i don't see the extra shifter but i see one of the fuses labeled 4wd. how do i tell
If you do not have the little shifter for high/low range to the left of the main shifter then its 2wd.
Thank buddy. Is there a guide on how to take apart the dash area to replace the head unit? and door speakers.
thanks.....;):
yeah id like to know how to replace the door speakers because my crazy sister and her music blew the front right and the tweeter
