My 06 v8 4x4 has some changes to suspension already done.
I pulled Xreas at 60k miles and put on FJ 4x4 springs and shocks ect at all 4 corners and a 1/2" CF spacer in front (1"lift height) and also have been running 265/70/17's (32") tire since the first day i bought it and i am also running FJ wheels for a slightly wider stance . (see sig at bottom). With all this done tires and FJ springs I am approx. 1" higher in rear and 2" higher in front over stock 4R (give or take) .
I want to lift a little more and have a 6pc Daystar kit sitting in my garage . I dont know if I should do springs and shocks or put the DS kit in instead ???? since I am already running heavier springs and shocks with the FJ stuff. I don't need a stiffer ride or more flex , I do great off road as it is. I just want a little more height / clearance . I will stay with the same size tires 32" 265/70/17 , but will be replacing them and maybe doing some aftermarket rims (not sure though , depends on what I see/find)
Im at 81k miles so far , no problems with anything .
Chime in with some input please .
