TheeMikeB
Part 1
So I've seen a few recent questions regarding install of speakers and door panel removal and thougth I'd share my recent install information. Originally I was going to do a full writeup but time was a factor and remembering to stop and take pics wasn't always on the top of my mind. I did however get some solid shots of the door panels, speaker brackets, and amp locations as well as wiring paths that I thought would be helpful. This isn't exactly step by step but I just wrote some of the big stuff down.
Also I'll start by saying I installed my HU last year and this install covers amp/speakers only and I don't have any pics of the HU install.
My system: Alpine IDA-x305 HU, Infiniti Kappa Five 5CH amp, JL Audio C2-650 componenents in front, JL Audio TRX-525cxi in Rear, Polk Audio 10" Dxi DVC sub mounted in a sound ordanance bass bunker.
First thing for me was to layout the amp and cossover locations under the drivers seat to get an idea of cable runs/paths.
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall009.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall009.jpg" border="0" alt="Photobucket"></a>
Once I had the locations fitted I began running the cable. I started with the power cable first from the battery. My amp called for a 4 AWG and I decided to use the existing hole in the firewall for the bulk cable bundle instead of trying to drill a new hole. (located on the driver side next to the brake master. I created a punch and lightly greased the power cable to slide throught the existing factory grommet.
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall005.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall005.jpg" border="0" alt="Photobucket"></a>
Showing under the dash where I came through:
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall004.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall004.jpg" border="0" alt="Photobucket"></a>
Then I ran the cable along the door runner and into the existing factory hole in the carpet for the seatbelt/airbag connector.
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall007.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall007.jpg" border="0" alt="Photobucket"></a>
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall008.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall008.jpg" border="0" alt="Photobucket"></a>
For my ground to the amp I ended up using a 4AWG negative battery connector because of the long thick fat terminal and mounted the ground to the left rear seat bolt after grinding away the paint using my dremmel.
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall014.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall014.jpg" border="0" alt="Photobucket"></a>
At this point I removed my center console parts (cupholder/shifter cover, and radio surrounds to gain access to the pre-amp outs) sorry no pics of this but the 4runner center comes apart extremely easlily. I then ran the preamp outs from the radio through the center console along the transfer lever, and down under the drivers seat. There is a pic down near the end of this showing where and how my cables run from the console to under my seat.
Now it was time for running the speaker wires... the fun part :redbrick: So at this point I did a door at a time starting with the front drivers door. I removed the door panel which I'm not going to go indepth on becuase I didn't take photos to explain what I was doing. But here is a photo of the front door panel removed. (this is actually the passenger door)
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall018.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall018.jpg" border="0" alt="Photobucket"></a>
close up of factory speaker
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall017.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall017.jpg" border="0" alt="Photobucket"></a>
I removed the factory speaker and installed the JL Audio:
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall028.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall028.jpg" border="0" alt="Photobucket"></a>
<a href="http://s342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/?action=view¤t=4RunnerAudioInstall029.jpg" target="_blank"><img src="http://i342.photobucket.com/albums/o439/gunnacostya/4runner%20Audio/4RunnerAudioInstall029.jpg" border="0" alt="Photobucket"></a>
Don't forget a bead of silicone glue along the rim to seal it off.
