quick question about rear diff lock...
swain
hey , was just wondering about the rear diff lock on my 96 limited. just wondering when its engages is the light on the dash supposed to blink or does that mean thers a problem?....
When I press the button to engage mine, on the side of the shifter, the light is constant. It does not blink. I have a '98, but I would think they would be alike. You might have a problem.
blinking means for some reason it is not engaging.
k so whats the proper procedure for locking the rear diff?, just to make sure i was doing it right?...
I'm shopping for a 4 runner and am trying to discribe to the sellers where this button is.
I saw a rocker switch mounted below the left AC vent labeled, "RR Diff Lock" on a 98 LTD. It was no where near the shifter. Do you think this was an after market add-on?
What's a good way to locate this option?
Thanks,
Thanks,
The factory Diff lock switch is located to the left of the steering wheel and is labeled RR DIFF LOCK. It is written in Orangeish letters and is not a rocker switch, just a button. Due to factory safeties, the locker can only be activated while the truck is in 4LO and is moving at less than 5MPH. If you are following those guidelines and it's still not engaging then you have a problem.
Here is a pic of what it should look like. (minus carbon fiber dash trim.)
Thanks,
I have seen the "RR Diff Lock" button in the same place on pictures, but I'm not sure what year it is. On my '98 Limited I have one shifter that does the normal Parking, Drive, Reverse, Low, and so on. I then have another shifter that has the "RR Diff Lock" button on the side of it. This shifter shifts into H4, N, and L4.
Yes, I know this isn't my 4runner, but it shows you where I'm talking about. Mine is on the side of this shifter.
1.jpg~original
Also make sure that you are stoppped and that it is in the correct position.
1.jpg~original
Are you sure that's what that button is for? Its not the factory location on ANY model 4Runner. I also have a 98 Limited with both shifters. The shifter on the left has a diagram on it that looks like this:
4LO
N
2HI
Then the button on the side of the shifter just says 4WD and is your 4HI. You have to push this button to engage 4HI and then from there you use the shifter for 4LO. Could you post a picture of your button?
Oh I see what you are saying. I guess I don't have a rear differential locker. I must have been mistaken and thought that every '98 Limited came with it.
Here is the shifter.
PIC_0004.jpg~original
This is where the button should be I suppose.
PIC_0005.jpg~original
Sorry if I confused anyone. I was mistaken. I learned something today. :).
So what does the rear differential locker do? Was it another option on the '98 Limited? When I press that button, "4WD", doesn't it shift into 4WD? LO, HI?
On the multi-mode autos of the '99-00 Limiteds the button on the 4wd shifter is the center diff lock which provides part time 4wd similar to AWD,pull that lever back and you are in 4hi.
To engage the diff lock you must stop the vehicle,put it in N then push the 4wd lever to the right and then forward then put in drive and go on your merry way.
The is the "grey wire mod" which allows diff lock operation in any mode including 2wd.
I'll post it here for those who are curious.
Ron, are you only talking about the front diff lock? I'm looking at a '99 this afternoon. Should I expect to see the rear diff lock botton in the location left of the wheel?
Thanks for all the help. Can't wait to get my new toy!!!
I'm sorry,I should have been clearer and separated my statement about the Limited's tranny since the diff lock operation is the same on all such equipped Runners. ('96-'00 only)
That which I described is for the rear diff lock and if the Runner is equipped with one it will have that RR DIFF LOCK button to the side left side of the wheel.
So a rear differential locker was optional even on the Limited models?
What exactly does it do? Just keep the two rear wheels turning at the same speed?
The diff lock positively locks the rear wheels together and doesn't allow slippage between the two wheels.
This is useful when climbing or forging deep snow or mud and just getting unstuck.
Bumping a very old thread here. I looked around, and this was the closest I could find. The issue the original poster describes is exactly what I'm experiencing. I put my truck in N, then pop it into 4Low......then hit my "RR DIFF LOCK" button. The "LOCK" light will flash - but it keeps flashing. And my 'ABS' light pops on solid at the same time. No matter if I'm stopped, moving slow, or whatever - the "LOCK" light keeps flashing and the 'ABS' light stays on. Switch back to normal, and all the lights go out.
Is my locker just gummed up somehow - from lack of use? Any ideas?
Try getting into a gravel lot, put it in 4lo, engage the locker, and drive slowly in a serpentine pattern, like an S.
Try doing this in both forwards and reverse.
If the locker has been dormant for a while it will take a little nudge to engage
Yeah, that might do it. I tried that a bit in my back alley - but there's no room to serpentine.
Rebumping an old topic sorry, but I haven't had the chance to use my button on my 98 limited. But if I use the 4hi button on the second shifter and make a turn, my inside rear wheel will spin faster than it need to (as if differential lock is engaged) is this normal?
